IoT System to control 433 MHz RC power sockets, PIR sensors, Door Sensors and much more.
Use NPM to install the platform on a RPi:
npm install iot-433mhz -g --unsafe-permUpload the single-arduino-tx-rx (https://github.com/roccomuso/iot-433mhz/tree/master/hardware-layer) sketch on your Arduino Nano.
Connect the 433 Mhz Receiver and Sender to the Arduino Nano, following this pinout:
And then connect the Arduino to the RPi through the Serial cable.
Its interesting work on IoT. If it would help you we are from Wia,Dublin and may be you can refer the our tutorials to give it a try http://blog.wia.io/how-to-publish-an-event-using-wia-for-nodejs
