2016: Ever since i was a young boy i wanted to build a rocket that could go high in to the sky. The end project should be able to record flight data and be able to send it back down to the ground in real time.
Update 2019: This rocket was able to fly to a hight of 2010 ft (615m). Flight data was recorded using an Arduino Uno.
Files
Launch Controller.pdf
Lunch Controller Circuit Design (PDF)
Adobe Portable Document Format -
172.50 kB -
07/23/2019 at 17:32
The rocket was lawn shed at a second rocket event and managed to reach an altitude of 3438ft. This was using a 3 Grain, Ceceroni, Blue Streak rocket motor.
The rocket flew three times with a maximum apogee of 2010ft. This is quite significant an achievement. the rocket project can now be moved on to its next phase.
