DAY | Project Logs Week 12 |
MON | This is the week when burning out is okay, and pushing hard only makes a difference due to all the preparing and planning. Working on more functions from my list today, and fine tuning the existing ones. |
TUE | Worked on approximation of production model size, based off of dimensions from TI datasheets. Thank you TI engineers for being so detailed oriented! |
WED | Working out power requirements, came up with a skin battery concept to offset power draw. Power draw is always a problem with any project it seems. However, this is not a continuously operating device. It has several modules all working independently, that don't need to be on all the time. The GSM for example, is only in use when outside the RF radius, then it only sends a text out once every 60 seconds. |
THU | Working on descriptions for hackaday project template today, and more coding. Updated project log entry for today. |
FRI | Last project log entry? Working on description and testing today. Worked on more sweat battery computations today, and my project description. |
