A breakout board for the FUSB302, a USB-PD PHY for BMC communication used in USB-C connectors
Rev 2 of the hardware is now available for sale on Tindie. The major changes are
I'm in the process of porting over the Google Chromium OS code into a standalone library for USB Power Delivery. I started with just the FUSB302-specific code. You find the github repo here. The example explains how to connect this breakout board to an Arduino. Then it reads the state of the CC pins, assuming it is plugged into a Downstream Facing Port.
The next major firmware upgrade will be a library that uses the FUSB302 library to send and receive PD messages and set states of the Type-C connector to perform all the higher-level functionality. Let me know if you are interested in helping out. Email me at jason@reclaimerlabs.com or follow me on Twitter @AscendedDaniel.
Hi,
I have just ordered the breakout board and want to experiment with getting an Attched USB-C phone into Host mode, but power sink. Can anyone tell me where to find the necessay format of the packets to put on the FIFO?
I have noticed in the example code that 4-bytes are send in a packet, but there is no detail as to what it was setting up.
Hey,
I hope you've found what you were looking for. But for anyone else wondering, the format of the power delivery messages is detailed in the specification available here : https://www.usb.org/document-library/usb-power-delivery-0
Nicolas
The "best" water filtration system can depend on various factors like the quality of your water source, the specific contaminants you need to remove, budget, and installation constraints. Here are some popular options across different categories: https://Waterfilters.systems
