My setup may change from Linux and. Raspberry Pi, to Windows and an ITX computer. Why? Because even though my screen and buttons were ADVERTISED as Pi compatible, they are not. The screen works, but the touch interface is not exactly compatible. The buttons, are not at all compatible. I would take a loss to return it, I doubt if I could sell it. So I may just order an ITX board and CPU and be done. Load Windows 7 and call it a day. But first I have to take some measurements. As with the ITX setup, all the cables have to run out of the case and plug into the back. I am not sure if I have enough room for that.
Randy Walker
