When it
comes to mass production, it's best fit to design the whole board with discrete
components rather than buying individual components, assembling and integrating
them. It simply adds to the cost as well as space. Under Adafruit's courtesy, I
have made a few changes with some components and added some design notes. The
OLED module is pretty straight forward apart from the bidirectional logic level
shifter. You can find more information about it in the following pdf: http://www.nxp.com/documents/application_note/AN10441.pdf
Refer the following schematic for the same:
fadilluquman
