Why did I create Light Relief?
I had bad dreams the other night, and got up in the night for a wee. I'd been talking to Doc as usual, about waveguides, earlier that evening and as I stood tinkling in the darkness the germ of an evil idea was born.
Sorry Ladies, you'll have to sit this one out until I figure out how to get it past Equal Opportunities.
* Female test pilots wanted.
This Piss-take is no longer officially sponsored by Social Services or associated with any connected agency. Enough is indeed enough, and Light Relief extends an apology to the individuals concerned.
Actually the green is by far the brightest of those, but the colours are pretty good. Slightly purple blue, but the ranges overlap nicely to give a solid white dot with all three, which hurts to look at.
First up, red diode. Nothing unexpected in there, these things run off a pair of AAA cells and have a small resistor to limit the current. I can just bypass the switch and pulse this one at KHz with no trouble.
Hahahah! Wicked man. :-D Yes, you shall come to the ball... ;-)
Invite sent ;-)
Test pilots, suggestions welcome...
