![](https://cdn.hackaday.io/images/417631531020543365.jpeg)
I filled cartridges will all the inks I have. I am likely to use noodlers and the UV absorbing ink , but I will start testing different labels soon. I picked up a Epson Workforce printer that uses these cartridges for 89 dollars from Office Depot. I believe I will dedicate the printer to making these invisible tags as to not mix inks.
![](https://cdn.hackaday.io/images/9272491531020282267.jpeg)
![](https://cdn.hackaday.io/images/6689491531020289035.jpeg)
![](https://cdn.hackaday.io/images/4618881531020290987.jpeg)
Noodlers White versus UV yellow, very close , but the yellow is 5 times the cost!
![](https://cdn.hackaday.io/images/1130241531020291027.jpeg)
![](https://cdn.hackaday.io/images/7060531531020301208.jpeg)
