Last night progress was made in finding places for the modern HD cameras that are both forward facing and the ceiling facing as well. I have 4 different camera options so they are not set in stone ,but at this time I have the 120 degree cam facing forward 5mp no IR filter, the ceiling camera has a shutter to add to remove the IR filter as needed. You may notice a large 1 inch clear lens. This lens collimated light from smaller sources into a sort of dot on the ceiling that is more more defined with less energy.
