Here is the QR code printed on paper in normal lighting of my home, the ink is completely invisible until it is hit with the UV and IR lighting.
This is a normally lit room but the violet shows so bright through the camera that the brightness auto adjust darkens the surrounding area. The QR is certainly readable with this newer light source.
