GPS added
A project log for "Connect" to an atomic clock in space! GPS, DCF77
This project is a clock with radio receivers which can receive the exact time from the GPS satellites or from the DCF77 transmitter.
hkdcsfhkdcsf 06/09/2014 at 15:260 Comments
I have updated the block diagram and the schematic with a GPS module interface. My plan is that You can select on a menu which source You want to use to synchronize the local clock a DCF77 signal or GPS.
