New project
12/09/2015 at 08:19 • 0 comments -
The Hackaday Prize: stage 2 video released
07/15/2014 at 04:46 • 0 commentsI have finished the stage 2 video for the Hackaday Prize. It is an overview about the current status and main operation of the clock.
Software details are updated
07/12/2014 at 12:33 • 1 commentI have written some more details about the SW. The SW static arhitecture and coding considerations.
DCF77 signal reception video added - must see!
07/07/2014 at 22:46 • 0 commentsOn the video below You can see on the oscilloscope how the DCF77 signal waveform looks like. You can also see how the two separate clocks are snychronizing to the DCF77 signal.
GPS signal processing details added
07/03/2014 at 05:27 • 0 commentsGPS signal processing high level design description added.
Video added
06/28/2014 at 08:53 • 0 commentsI have updated the detailed description with a video about the menu. Further videos and design description will come.
Temperature measurement
06/25/2014 at 20:21 • 0 commentsI have added the detailed description of the temperature measurement algorithm.
First blue PCB populated and mounted
06/22/2014 at 09:15 • 0 commentsI have just finished mounting the components on the first PCB. I mounted the populated PCB on a Deltron enclosure. Uploaded some project pictures about it.
PCBs arrived
06/20/2014 at 08:49 • 0 commentsI have just received the new blue PCBs, I will have 2 PCs manufactured in red too next week. The PCB is nicely fits into the Deltron enclosure. Beauty.
First GPS message received
06/17/2014 at 18:56 • 0 commentsWorking on the UART interface driver of the GPS module right now. Just received the first GPS sentence containing the UTC from the PmodGPS module. Still have to work on handling the framing and overrun errors..., new PCBs also on they way, lot of work ahead...
hkdcsf
