After having to wait for resistor arrays since I placed the wrong footprint size on the main PCB I have finally fully assembled a Rev A.
I did run into a few quick fixes such as things I should add to the silkscreen. I also found out after much frustration that there needs to be a 1k resistor on each PNP transistor between the base and emitter otherwise 3.3V is not enough to turn off the display. I hand corrected the above but issues with the 3.3V LDO are making me consider scraping running from 4xAA anyways and sticking with 2xAA or possibly a LiPo for Rev B. I found that the voltage from the LDO is 4.1V and I suspect it has to do with adding the 1k resistor to the PNPs. I have enough to assemble 5 more so the next one will use 2xAA and skip the LDO, I will have to see if the display is bright enough.
Anyways it is nice to be able to hold the real thing instead of staring at a render in FreeCAD.
Look into "Digital Transistor" e.g. http://www.onsemi.com/PowerSolutions/product.do?id=MUN2111
It has resistors built-in and footprint compatible with regular transistors. i.e. save you a board spin. There are different values of these resistors. Just need to search for them.
Thanks, I will be sure to check it out.
Forgot to say: Between the external series resistor that you had and the internal ones, you should be able to make voltage divider of the right ratio.
That actually looks awesome. Nice styling.
Thanks
