There is a desire to edit config files & notes on a phone without shuffling files around, typing on the phone screen, or using busybox on ADB.
Webphone needs an editor which shows the file contents in a text box, has a save button, revert button. Browser text editing is horrendous but better than nothing. It would be the absolute minimum way of changing a text file.
After some heroic HTML POST handling, it was done. Need undo or revert? Just hit the back button.
There is 1 kaboom case. If a text editor on the phone changes it & the user resends the POST in the browser, it'll overwrite the phone changes. The post could contain an md5sum of the previous save & it could reject the post if the md5 doesn't match what's on the phone.
This became kind of a pain after a while. It needs to retain the size of the text box in a cookie.
