Sleep mode in Linux works about 90% of the time, but virtualbox is the 1 program which crashes every time.
Suspend with a virtual machine running, resume with the virtual machine running, & your VDI image is gone for good.
The leading idea is putting all the virtual machines in pause before suspending the host. There's no way to pause all the virtual machines with a wildcard, but 1 VM at a time can be paused with:
VBoxManage controlvm 'The Grid' pause
In theory, this has to go in /etc/pm/sleep.d/10_virtualbox
#! /bin/sh
case "${1}" in
hibernate|suspend)
resume|thaw)
VBoxManage controlvm 'The Grid' resume
esac
All those files are run before a sleep or wake. In reality, there's no consistency in the naming of the hibernate operation, so they have a bunch of random names in the switch statement. The Virtualbox screen greys out a nanosecond before sleep to show it's working. A sleep statement would make it more obvious.
Helas, if the virtual machine isn't running, the script fails & the hibernate command aborts. Another problem is new lines have to be added for every single virtual machine.
There's
VBoxManage list runningvms
to show all the running & paused virtual machines.
VBoxManage list vms
to show all the virtual machines.
#!/usr/bin/python
# pause the virtual machines
import os
import sys
import subprocess
command = sys.argv[1]
text = subprocess.check_output(['VBoxManage', 'list', 'runningvms'])
lines = text.split('\n')
for i in range(len(lines)):
words = lines[i].split(" {")
if len(words[0]) > 0:
# strip the "
name = ""
for c in words[0]:
if c != '\"':
name += c
print("'" + command + "'ing " + name)
subprocess.call(['VBoxManage', 'controlvm', name, command])
It needs an increasingly sophisticated python script to handle all the corner cases.
