Late in the text editor game to be sure, but lions have been using nedit for 30 years now. It has limitations & bugs, manely a tendency to open multiple instances of itself to edit the same file. Then there's no way to copy the filename to the clipboard. It's always a pain to make it apply C++ style comments. It's a pain to switch between tabs & emulated tabs.
The mane thing lions need is a way to invoke an editor inside lxc-attach, ssh, xterm, serial terminal, adb, & automatically detect if it already has an editor instance for the file. The editor would then have 1 instance for each file, no matter where the file was opened. If the file wasn't on a local filesystem, the editor would communicate with the client through the terminal it was invoked on. For a serial terminal & ADB it would need a special terminal program & ADB hack which could multiplex messages with console characters. Ssh has ways of tunneling sidechannel data. Everything inside LXC is in a /var/lib/lxc directory.
Maybe it would rely on a table of mount points to detect equivalent files, then always assume ssh, serial terminal, & ADB were not accessing any local mount points.
You can open 'screen' with permissions to allow connection to open connections. Then do what you will with the sideband control including taking over the session, triggering on text/events, sending files right over the session, etc. On topic, I use gVim. It alerts on multiple copies of the same open file provided you have some temp directory writable.
