Just uploaded the draft outline schematic to github.
Next step is probably to use an FPGA dev board I have to build up the switching logic and see how much real estate it uses, and connect it up to the Pi (skipping the hub microcontroller and just using the Pi to start with)...
Andrew Bolin
