The first real use of HControl! I have build a RC car to be able to test HControl in a real life situation. The HControl mudule with the app did fine. The car? Well.. judge for yourself.
There are still some improvements to be done. The steering right now is reversed. Not ideal when you want to control a car. This shows why the controls needs to be configurable and reversing will definitively be one of the parameters. So next up will be improving the app by making it more robust in terms of use and adding configurable controls. And maybe some work needs to be done on the car.
hylke44
