Project IoT ESP8266 ESP12E
For components you can use standard components, no need to use SMD components as I created in this article to simplify soldering.
Public Chat
In this article I want to create a tool called the Telegram Garden.
Project IoT for this garden or plantation I made to be able to monitor her special garden for soil moisture, temperature, and also air humidity around the garden that I want to monitor.
But also the tool I made as IoT I can enable it as a control to power the irrigation pump machine so that I can flush the plant remotely through the tools I made.
To be able to communicate with this tool I use Telegram chat app as an intermediary, so to monitor data and control it I just need to chat as usual later.
IoT.sch
CODING ARDUINO
sch - 912.18 kB - 04/17/2018 at 01:16
Download
Universal-Arduino-Telegram-Bot-master.zip
LIBRARY TELEGRAM
Zip Archive - 76.78 kB - 04/17/2018 at 01:16
Download
PCBWAY.ino
SKEMATIK EAGLE
ino - 3.93 kB - 04/17/2018 at 01:16
Download
  • 1 × ESP8266 12E
  • 2 × DHT11
  • 11 × Terminal Screw 3p
  • 12 × Tactile switch
  • 13 × Diode 4007
View all 16 components
Rich text editor
taituhacker wrote 05/10/2018 at 04:25 point
Which software opens IoT.sch ?
can you share  IoT.PCB ?
thank you, i very like it
Modzer0 wrote 04/23/2018 at 12:48 point
Might want to replace that DHT11, they're not exactly the most reliable part and the measurements are sometimes questionable. I've seen a lot of trouble caused by them when people try to use them in automation systems.
