I finally have all the parts soldered on my Control board, and tested that.
My hole size for the speaker was too small so I had to drill them out. There was pretty much no pad left after that so that's why there's the two jumper wires on the back of the board. I also placed the RJ-12 jack a little too close the to headers for the chipKit so it gets a little wanked over to the side.
Also I need some standoffs to keep the LCD screen and the control board from touching.
Here is everything together. So many PCB colors. I loaded up the example sketch from Henning Karlsen UTFT library and nothing happened. Then I remember the backlight on the screen has a PWM input for dimming and I wasn't giving it anything. So I fixed that and bam images on the screen. Now I can start designing screens.
