Recently I breadboarded the pH/ORP amplification and offset circuit. I don't have any probes or cal/check solutions so I just set up a voltage divider with a trimmer pot to simulate the different voltages. Everything worked as I expected. Other than that I've been working on code here and there, focusing mainly on UI.
Skyler Brandt
