That's right. This universal splice box can be used without a soldering station. Just twist the wires inside and add the hot meld glue:
- Print the splice box
- Peel off the insulation
- Insert the wires into the box
- secure the wires using cable ties
- Twist the wires together
- Fill in the box with hot melt glue
- Place the lid
- Wait for the glue to set and you're good to go
Marius Taciuc
