Helps you save water by turning red after one Liter
Thanks. An enclosure would definitely help.
I like the visual aspect along with the water conservation theme. Is the unit water proofed or water resistent? I assume there is an enclosure to prevent the Arduino board from getting wet.
Currently working on: https://hackaday.io/project/4698-clouden
Marcel
nodemcu12ecanada
Anteneh Gashaw
aliahsan.syed
Yes, delete it Cancel
You are about to report the project "Augmented Water", please tell us the reason.
