Here's essentially the same thing but with only one port, and no UPS. It is basically just a wireless 120VAC relay with a manual override (the switch). The case is just a regular blue PVC electrical box. Simple, but served me well for a long time.
The relay board is just visible inside, without taking it all apart to photograph it....
This worked well, but I do like the UPS on the microcontroller. Of course, this whole small unit could be plugged into a regular UPS. Still, it only had one port (the two outlets are bridged).
