@DL101 tells me about the Intel 3002 :
http://www.cpu-world.com/CPUs/3002/
This rings a bell, with the following differences :
- only one bit per slice for the AMBAP
- memory is linked directly to each of AMBAP's slices
- AMBAP has only 8 or 16 registers (not 11)
I need to find more documentation about this chip now... The die shot is glorious :
Thanks DL !
Yann Guidon / YGDES
Oh and https://en.wikichip.org/wiki/File:1975_Intel_Data_Catalog.pdf
Here is a bit more about it:
http://reports-archive.adm.cs.cmu.edu/anon/scan/CMU-CS-77-mcwilliams-fuller.pdf
Thanks ! I saw it too but.... I'd like to find an actual datasheet, user manual, etc. :-)
Hey Yann, try this out: http://www.cpu-zone.com/3002/intel3002.pdf
http://www.datasheets360.com/part/detail/mc3002/-1572413705640479543/?alternatePartManufacturerId=0
Also it is discontinued.
@David H Haffner Sr yay thanks !
