Been a quiet week, Still waiting for my 3v3 mini pro's and various other components :)
As soon as parts arrive i am going to tidy up the controller, I have a decided to add an NRF24L01 with external antenna to the controller. At least while i am waiting for the parts i can work on the code a bit.
Need to do.
*Possibly put the NRF24 and arduino to sleep in the PIR's, (Needs testing as i do not want there to be to much of a delay moving the cam.)
*Possibly have each PIR on it own channel. At the moment they share the same i have two PIR's which seem to be getting along will see what happens when new boards arrive.
*I need to spend a bit more time R&D existing external security PIRs, (Need to learn to direct the sensor help reduce false detections.)
*Been thinking of adding a solar panel to the PIR's to help with battery.
*Start to design a custom board, (First version will be 3v mini pro shield)
