So here's the first working python script, ignoring all good practices like checking for return values or doing things in the right place. It also doesn't output zero and ones, but a float that is the L2 norm between the current frame and the reference frame. But in a way it does the job:
#!/usr/bin/env python
from __future__ import print_function
import sys
import gi
from gi.repository import GObject as gobject, Gst as gst
from streamlink import Streamlink, StreamError, PluginError, NoPluginError
import cv2
import numpy
def exit(msg):
print(msg, file=sys.stderr)
sys.exit()
class StreamlinkPlayer(object):
def __init__(self):
self.fd = None
self.mainloop = gobject.MainLoop()
# This creates a playbin pipeline and using the appsrc source
# we can feed it our stream data
self.pipeline = gst.Pipeline.new("player")
source = gst.ElementFactory.make("uridecodebin", "decodebin")
source.set_property("uri", "appsrc://")
self.pipeline.add(source)
self.vconverter = gst.ElementFactory.make("videoconvert", "vconverter")
vsink = gst.ElementFactory.make("appsink", "videosink")
vsink.set_property("emit-signals", True)
vsink.set_property("max-buffers", 1)
caps = gst.caps_from_string("video/x-raw, format=(string){RGB}")
vsink.set_property("caps", caps)
vsink.connect("new-sample", self.on_new_sample)
filter = gst.ElementFactory.make("videorate", "fpsfilter")
filter.set_property("max-rate", 1)
self.pipeline.add(self.vconverter)
self.pipeline.add(filter)
self.pipeline.add(vsink)
self.vconverter.link(filter)
filter.link(vsink)
# self.vsink = vsink
source.connect("source-setup", self.on_source_setup)
source.connect("pad-added", self.on_pad_added)
# Creates a bus and set callbacks to receive errors
self.bus = self.pipeline.get_bus()
self.bus.add_signal_watch()
self.bus.connect("message::eos", self.on_eos)
self.bus.connect("message::error", self.on_error)
def exit(self, msg):
self.stop()
exit(msg)
def stop(self):
# Stop playback and exit mainloop
self.pipeline.set_state(gst.State.NULL)
self.mainloop.quit()
# Close the stream
if self.fd:
self.fd.close()
def play(self, stream):
# Attempt to open the stream
try:
self.fd = stream.open()
except StreamError as err:
self.exit("Failed to open stream: {0}".format(err))
# Start playback
self.pipeline.set_state(gst.State.PLAYING)
self.mainloop.run()
def on_source_setup(self, element, source):
# When this callback is called the appsrc expects
# us to feed it more data
print("source setup")
source.connect("need-data", self.on_source_need_data)
print("done")
def on_new_sample(self, appsink):
sample = appsink.emit("pull-sample")
buf = sample.get_buffer()
caps = sample.get_caps()
height = caps.get_structure(0).get_value('height')
width = caps.get_structure(0).get_value('width')
(result, mapinfo) = buf.map(gst.MapFlags.READ)
if result == True:
arr = numpy.ndarray(
(height,
width,
3),
buffer=buf.extract_dup(0, buf.get_size()),
dtype=numpy.uint8)
resized_refimage = cv2.resize(refArray, (width, height))
sum = int(0)
diff = cv2.norm(arr, resized_refimage, cv2.NORM_L2)
print("diff = " + str(diff))
buf.unmap(mapinfo)
return gst.FlowReturn.OK
def on_pad_added(self, element, pad):
string = pad.query_caps(None).to_string()
print(string)
if string.startswith('video/'):
pad.link(self.vconverter.get_static_pad("sink"))
def on_source_need_data(self, source, length):
# Attempt to read data from the stream
try:
data = self.fd.read(length)
except IOError as err:
self.exit("Failed to read data from stream: {0}".format(err))
# If data is empty it's the end of stream
if not data:
source.emit("end-of-stream")
return
# Convert the Python bytes into a GStreamer Buffer
# and then push it to the appsrc
buf = gst.Buffer.new_wrapped(data)
source.emit("push-buffer", buf)
def on_eos(self, bus, msg):
# Stop playback on end of stream
self.stop()
def on_error(self, bus, msg):
# Print error message and exit on error
error = msg.parse_error()[1]
self.exit(error)
def main():
if len(sys.argv) < 4:
exit("Usage: {0} <url> <quality> <reference png image path>".format(sys.argv[0]))
# Initialize and check GStreamer version
gi.require_version("Gst", "1.0")
gobject.threads_init()
gst.init(None)
# Collect arguments
url = sys.argv[1]
quality = sys.argv[2]
refImage = sys.argv[3]
global refArray
image = cv2.imread(refImage)
refArray = cv2.cvtColor(image, cv2.COLOR_BGR2RGB)#cv2.COLOR_BGR2GRAY)
refArray = cv2.blur(refArray, (3,3))
# Create the Streamlink session
streamlink = Streamlink()
# Enable logging
streamlink.set_loglevel("info")
streamlink.set_logoutput(sys.stdout)
# Attempt to fetch streams
try:
streams = streamlink.streams(url)
except NoPluginError:
exit("Streamlink is unable to handle the URL '{0}'".format(url))
except PluginError as err:
exit("Plugin error: {0}".format(err))
if not streams:
exit("No streams found on URL '{0}'".format(url))
# Look for specified stream
if quality not in streams:
exit("Unable to find '{0}' stream on URL '{1}'".format(quality, url))
# We found the stream
stream = streams[quality]
# Create the player and start playback
player = StreamlinkPlayer()
# Blocks until playback is done
player.play(stream)
if __name__ == "__main__":
main()
Next:- modify it to create a binary value for availability
- add more checks
- use a better comparison algorithm (the difference between available and unavailable is a bit low: about 60000 vs 49000)
- maybe: add a config file
- maybe: add possibility to change the reference image during runtime
