This is less of an update, more of a keep alive. I’m waiting on the last of the parts to arrive from China, so I can do final fit tests before drilling holes in frames, but I did try a quick fit test of the Y axis
I suspect it is going to have way too much deflection in the Z-axis, which is disappointing, but not unexpected. I’ll looking into alternative linear rails options. That won’t be a blocker right now though, as I should get on to testing the control board.
