To speeding up the uploading process, you will need to sacrifice some functions in the library, for example the "reverseTrack" with less code to upload, faster will be the process, I attached two pic, one with the full code, the other without that function. The difference is around 6 seconds less.
Before
After
Salvador Mendoza
