Well today I've added a bluetooth module which i was planning on using in another project but wasn't quite what i needed. As you can see in the video below it works quite well and was easy to set up, just wire it up to pins 0, and 1 and the mega (Rx, Tx) pair with the laptop and select connection. In the future i would like to have maybe a Raspi connected so i can get, email alerts, maybe interact with outputs, and change sensor settings.
dannyritchie
