Received new PCB for Charge Controller
A project log for Solar Powered Mobile Device Charging Hat
Solar cells in the hat charge an internal LiFePO4 battery, which can then charge any mobile device via USB
msummers123msummers123 • 11/04/2016 at 20:28•0 Comments
I finally received the custom printed PCB for the hats, to replace my old charge controller I hacked together from spare parts. You can see it here:
Other than being smaller than the old electronics module, its also more efficient, can charge (slowly) in low light conditions, and allows the battery to be charged from external USB power. Going to do more testing with this soon, stay tuned.
