The simplest function of the system is also one of my favorites. It automatically refills the water tank of my coffee maker. All it needs is a float switch and a solenoid valve that lets fresh tap water flow in the tank.
![](https://cdn.hackaday.io/files/14862635855808/20190930_174021.gif)
Thanks to the SCADA like the design of my smart home system it is easy to derive the water usage from the time the valve was open (@ Level 3/4: A Raspberry PI With Node-RED and Grafana).
Every step up on the following graph represents a refill of the tank.
![](https://cdn.hackaday.io/images/622231570255216298.jpg)
Don't worry there are some safety functions implemented in Level 2: (A Raspberry PI with CodeSys software PLC ) of the system. Such as maximum filling time or only refill when someone is at home.
And it is possible to trace all actions within Grafana:
![](https://cdn.hackaday.io/images/457841570255230594.png)
