AI-on-the-edge implementation (MQTT)
A project log for DIY Home Automation
A DIY smart home system the SCADA way...
stefanschnitzerstefan.schnitzer 09/04/2022 at 15:040 Comments
Since I have moved from a rental apartment to a house, it is possible to install some things I have long dreamed about.
The first addition to my smart home system should be a real flow meter for the main water supply pipe. But while I was browsing the web for the cheapest flowmeter, I found a better solution. -To use the existing water meter and digitize it.
The AI-on-the-edge-device from jomjol on github  https://github.com/jomjol/AI-on-the-edge-device is easy to implement and works flawlessly. The data is send via MQTT to my Nodered and Soft-plc...
The Web-UI:
My water usage from the last 7 days:
The 3d-printed enclosure is still missing some parts:
