Just a short log with a video of the hand grasping at a suncream container. It doesn't pick the container up, with my thinking if a put the finger pads on it have instead of the ABS exoskeleton just slipping over the surface.
Playing around with what this hand can pickup and especially because it is a soft hand it should be capable of grasping different/oddly shaped objects.
Nelson Phillips
