8 LED CONTROL OVER INTERNET
Control an array of 8 leds over the internet
In this project I'm gonna show you how to control an array of 8 leds (could be more) over the internet, at this moment this project is working by sending trough a webpage an http header with a value inside, arduino server is gonna check the http header for a value after the "?" and lights up a led or start a light sequence.
Here is a little demonstration on how it works once is completed.
And that is the schema to follow in order to make it works with the code below
EthLedcontrol.ino
The source file for make this example project work
ino - 5.50 kB - 09/23/2016 at 09:37
Download
  • 1 × Arduino Etherneth Shield 2
  • 1 × Arduino Uno R3
  • 4 × Blue Led
  • 4 × Red Led
  • 1 × Ethernet Cable
View all 6 components
View project log
redstonecraftcart wrote 06/01/2017 at 18:25 point
how do you control it?
