I added a link to my dropbox where I will post all the robot it's files so you can download it.You may get a warning from your pc when downloading the program but I can assure you that it is safe, it is just the application to get the subscriber amount from your YT chanel and send this number to the COM port. Your PC will probably give you this warning every time you download an exe file.
