With more people starting to follow this project, i guess it's time to start improving and rebuilding parts ;)
I think this unit has reached it's bodge limit, so i will probably need to go with a whole new version. This time i'll use a plastic support (less chance of severing a finger while it's running), powering the display without having to spin the battery, and either getting the images to the display by sd card, or some kind of serial data link. If i feel brave enough to do the extra fiddly soldering i might even use surface mount parts to minimise the visible circuitry.
sad_ken
