Sadly no photos yet, but i've got everything wired up, and enough coding done to make it fully operational (although i could do with adding a mode to vertically flip the image...).
Interesting side note:
I'm currently testing it with a 24 x 1024 repeating version of this image...
when running the light wand at the right speed, and waving it back and forth like a nutter (only current way of testing the image) you get an animated fire effect. Could be the start of a new sub project....
