TORQUE CALCULATION
MOTOR 3
MOTOR 2
MOTOR 1
Product Specifications
Height Adjustment | 2 Feet ( Automatic ) |
Distance from stand | 1.5 Feet |
Battery Life | 4 Hours |
AC supply | 220-230 V |
Current Required | 2-3 A |
Food Volume | 1.5 Liters |
Food Types | Semi-solid |
Sensor to prevent spoon hitting the teeth | Yes |
Total Weight | 2-3 Kg |
Device Height | 10 Inches |
Device Diameter | 14 Inches |
Legend No. | Legend Description |
1 | Base |
2 | Upper rim of the base |
3 | Rotation Adjustment |
4 | Channels for distance adjustment |
5 | Motor for rotating the bowl |
6 | Bowl |
7 | Motor for guiding the spoon to scoop the food |
8 | Motor forspoon movement |
9 | Spoon |
10 | Haptic Feedback Button |
11 | Battery Pack |
12 | Cross scissor lift |
13 | Electronic housing |
14 | Camera |
15 | Level 1 |
16 | Level 2 |
17 | Level 3 |
18 | Assistive feeder device |
19 | 220-230 V plug |
