TORQUE CALCULATION
MOTOR 3
MOTOR 2
MOTOR 1
Product Specifications
| Height Adjustment | 2 Feet ( Automatic ) |
| Distance from stand | 1.5 Feet |
| Battery Life | 4 Hours |
| AC supply | 220-230 V |
| Current Required | 2-3 A |
| Food Volume | 1.5 Liters |
| Food Types | Semi-solid |
| Sensor to prevent spoon hitting the teeth | Yes |
| Total Weight | 2-3 Kg |
| Device Height | 10 Inches |
| Device Diameter | 14 Inches |
| Legend No. | Legend Description |
| 1 | Base |
| 2 | Upper rim of the base |
| 3 | Rotation Adjustment |
| 4 | Channels for distance adjustment |
| 5 | Motor for rotating the bowl |
| 6 | Bowl |
| 7 | Motor for guiding the spoon to scoop the food |
| 8 | Motor forspoon movement |
| 9 | Spoon |
| 10 | Haptic Feedback Button |
| 11 | Battery Pack |
| 12 | Cross scissor lift |
| 13 | Electronic housing |
| 14 | Camera |
| 15 | Level 1 |
| 16 | Level 2 |
| 17 | Level 3 |
| 18 | Assistive feeder device |
| 19 | 220-230 V plug |
Ayushman Talwar
