I Would like to monitor
- Ambient Temp
- Tank Temp
- To Booster Temp
- From Booster Temp
- Supply Water Temp
- Battery Voltage ( The sensor unit will be mounted on the roof and powered by a 12V SLA for the moment with possible Solar charging)
Use a Node MCU Board
5 DS1822 water proof Sensors
From experience using the NODE MCU board running a logging system updateing a BLYNK server every 2 seconds a 12V 12AH SLA last about a week.
I dont think I need that kind of resolution so will initially set the update rate to once every 15minutes and put the ESP8266 to sleep between updates. As I will me monitoring the battery voltage I will be able to reasses the energy requirements once I start to obtain real data
Saabman
