I want to build motorized roller skates and make it as compact as possible so its not bulky and is easy to use.
Details
This project will consist of a very small 2-stroke motor and then add it to skates, it will either be chain driven or gear shaft. The throttle and kill-switch will be the first to be install to avoid accidents or problems.
