I was able to use the existing code I had prepared for esp8266lighthouse (https://github.com/cnlohr/esp8266lighthouse) and was able to modify the provided code from triad (https://github.com/TriadSemi/TS4231/blob/master/ts4231.cpp) to operate on the ESP8266.
I tried configuring the TS4231 using the default configuration word 0x392B, which is the default configuration. The TS4231 conveniently allows you to read back the configuration word so I verified it could have its configurations set arbitrarily. Sadly, when operating the base stations at 1.8MHz, no more envelopes or data passed. So, I figured maybe the message I need to send the TS4231 a different configuration, so I chugged away...
By using esp82xx's custom command system, it allows me to write javascript code to control and monitor things, so, I wrote some javascript to read GPIO inputs and configure the TS4231. Automatically advancing through. If the GPIOs ever received any lighting events, I would display them. It allowed me to automatically test all 14-bit codes over the course of about 6 hours.
function GPIOUpdateCallback( n, m )
var buttons = n;
if( buttons != lastbuttons )
mark = 1;
lastbuttons = buttons;
if( countthis++ > 120 )
if( mark )
console.log("!!!\n");
document.getElementById( "results" ).innerHTML += commandid + "<BR>";
mark = 0;
//Set the configuration word.
QueueOperation( "CS"+commandid, function( req,data) { $("#custom_command_response").val( data ); } );
document.getElementById("current").innerHTML = commandid;
commandid++; //Advanced to next configuration word.
countthis = 0;
I tried all 16384 combinations of config words. There were no lighting events from the TS4231 after it was configured with the 1.8 MHz base station. This is disheartening. I am worried the TS4231 cannot operate at all unless there is encoded data in the OOTX and sweeps.
Up Next: Will be trying to use Nairol's custom base station firmware to increase frequency of base station and see if there's any combinations that the configured TS4231 will work with.
CNLohr
