The first iteration of this project will be a rechargeable cellular module with an E-ink display for the purpose of showing bus arrival times at a specific spot. This device will be mounted outside to or near a bus stop. This requires it to be weather-proof, work outside of wifi range, tamper resistant, and last long enough that the installer isn't burden by charging cycles. Since I do not want to have to deal with the complexity of solar panels on the first try, this version will be charged via a common 5V usb battery pack.
Andrew Sowa
Chron-O-John
Pocket Energy
Arya
Arik
