This represents my current research references for building a non invasive test for measuring ketone levels in insulin dependent diabetics.
Journal References :
(working to complete)
- Thati, A., Biswas, A., Chowdhury, A. R., Say, T. K. (2015). Breath Acetone-Based Non-Invasive Detection of Blood Glucose Levels. International Journal on Smart Sensing and Intelligent Systems, 8(2), 1244-1260.
- Rydosz, A. (2015). A Negative Correlation Between Blood Glucose and Acetone Measured in Healthy and Type 1 Diabetes Mellitus Patient Breath. Journal of Diabetes Science and Technology, 9(4), 881-884.
- Suchorska-Wozniak, P. (2017). Detection of Acetone Using Resistive Gas Sensors. PhD Interdisciplinary Journal, x(x), 201-206. Zvyagin, A. A., Shaposhnik, A. V., Ryabtsev, S. V., Shaposhnik, D. A., Vasilév, A. A., Nazarenko, I. N. (2010). Determination of Acetone and Ethanol Vapors Using Semiconductor Sensors. Journal of Analytic Chemistry, 65(1), 94-98.
- Zhang, Y., Zhao, J., Du, T., Zhu, Z., Zhang, J., Liu, Q. (2017) A Gas Sensor Array for the Simultaneous Detection of Multiple VOC's. Scientific Reports |7:1960| DOI:10.1038/s41598-017-02150-z www.nature.com/scientificreports
- Fine, G. F., Cavanagh, L. M., Afonja, A., Binions, R. (2010). Metal Oxide-Semiconductor Gas Sensors in Enviornmental Monitoring. Sensors, 10, 5469-5502 doi:10.3390/s100605469
- Anderson, J. C. (2015). Measuring Breath Acetone for Monitoring Fat Loss: Review. Obesity, 23(12), 2327-2334.
- Szulczynski, B., Gebiki, J. (2017). Currently Commercially Available Chemical Sensors Employed for Detection of Volatile Organic Compounds in Outdoor and Indoor Air. Enviornments, 4(21) doi:10.3390/enviornments4010021
- Kao, K., Hsu, M., Chang, Y., Gwo, S. and Yeh, J. A. (2012). A Sub-ppm Acetone Gas Sensor for Diabetes Detection Using 10 nm Thick Ultrathin InN FETs. Sensors,12, 7157-7168; doi:10.3390/s120607157
- Shaposhnika, A., Zviagin, A., Sizaska, E., Ryabtsevb, S., Vasiliev, A., Shaposhnik, D. (2014). Acetone and ethanol selective detection by a single MOX-sensor. Procedia Engineering 87, 1051 – 1054.
- Wang, C. C., Weng, Y. C., Chou, T. C., (2007). Acetone sensor using lead foil as working electrode. Sensors and Actuators B 122, 591–595
- Galassetti, P. R., Novak, B., Nemet, D., Rose-Gottron, C., Copper, D. M., Meinardi, S., Newcomb, R., Zaldivar, F., Blake, D. R., (2005). Breath Ethanol and Acetone as Indicators of Serum Glucose Levels: An Initial Report. Diabetes Technology & Therapeutics, 7(1), 115-124.
- Musa-Veloso, K., Likhodii, S. S., and Cunnane, S. C., (2002). Breath acetone is a reliable indicator of ketosis in adults consuming ketogenic meals. Am J Clin Nutr,76, 65–70.
- Ruzsányi1, V., and Kalapos, M. P., (2017). Breath acetone as a potential marker in clinical practice. J. Breath Res. 11 024002 https://doi.org/10.1088/1752-7163/aa66d3
Websites/Blogs, etc. :
- https://jenslabs.com/category/electronics/ketosis-detector/ An Arduino Based Ketosis Detector (for detecting dietary induced ketosis)
- http://nootropicdesign.com/projectlab/2010/09/17/arduino-breathalyzer/ Arduino Breathalyzer: Calibrating the MQ-3 Alcohol Sensor
- https://keto-mojo.com/ Ketone and Blood Glucose Monitoring System (blood and strip based test for blood ketone levels)
- https://www.thediabetescouncil.com/the-ultimate-guide-to-ketone-testing/
Tom Meehan
