v1.1 is alive!
A project log for Hardware Reverse Engineering Learning Platform
a hardware version of your crackme and reverseme games for learning hardware reverse engineering techniques without expensive tools
tom-van-den-bonTom Van den Bon • 08/08/2014 at 13:53•0 Comments
I soldered up the new board, hooked it up onto the nucleo and loaded some test programs and all seems good. Communication to the two RE processors work and all led's go blinky. Time to write some real code now. Both the RE processors (the two atmega328's) are loaded with the arduino bootloader. Next step is to write code for the nucleo board that can upgrade both RE processors using the bootloader to setup the RE scenario.
