Initially I was working to reverse engineer the interface for the optical trackpad/joystick/navigation buttons used on a number of blackberry phones.
These modules are essentially tiny cameras with built in logic to determine the frame-by-frame differences of the surface being tracked, usually a fingertip, but a tongue should work as well.
I purchased modules from two different phone models, but they turned out to use completely different internal tracking modules.
