Hamming 24,16 ECC
06/21/2014 at 22:59 • 0 commentsLoFi uses Hamming error-correcting codes to detect and correct transmission errors. I've chosen a version that is not the most data efficient, but is a reasonable compromise because:
- The cost of the microcontroller increases with the amount of program space
- The power usage of the microcontroller increases with its speed. So, I chosen to run the ATtiny at only 1 MHz
- The computational requirements increase as the checksum code is applied to larger number of bits
I was surprised on how poorly the textbook code performed on an Atmel AVR processor. I wrote a new implementation that reduced it to 55 bytes of program space and a faster run time.
The resulting library is available in the links section.
There is more information about Hamming codes and this implementation, if you are interested:
http://www.robotroom.com/Hamming-Error-Correcting-Code-1.html
Dealing with static
06/21/2014 at 01:35 • 0 commentsIn order to support multiple senders on the same frequency (433 MHz), they must cooperate with each other by keeping their transmitters turned off except when they need to send a message. Therefore, most of the time, all of the transmitters are turned off.
When all of the transmitters are turned off, this is what the listener hears:
Have you ever tuned your radio to a frequency that doesn't have a station broadcasting on it? What do you hear? Silence? Nope. Static!
The listener is hearing static most of the time. How is it supposed to differentiate between noise and signal? Certainly a checksum in the data helps, but if the receive port starts reading a couple of bits too early (because the static looked like the start of a byte), then the entire message will be lost because the listener bit stream is out of phase with the sender bit stream.
Some people send a series of letter 'U' characters (repeating bit pattern) and hope that the listener syncs up. However, a better choice is to fully enable the transmitter for at least 10 bits (1 start + 8 data + 1 stop). This provides the following benefits:
- The listener can differentiate a long high period from static, since static often has low bits
- The first low bit after the long high signal is a serial start bit, thus synchronizing the bit streams
- The listener doesn't need to throw away any bytes (like 'U')
* Most importantly, the receiver hardware turns down the auto-gain (volume), just like you would turn down the volume when you hit a loud station. Thus, the static is quieted.
The above oscilloscope trace comes directly from the receiver hardware -- not the microcontroller. Look how clean the data signal is. This demonstrates that the $1 eBay 433 MHz transmitter/receiver is actually quite capable.
An interesting phenomenon of the receiver hardware auto-gain is that static is not heard by the listener for some time even after the transmitter has turned off again (see below). But, eventually it creeps back as the receiver turns up the volume again to hear fainter messages.
Fortunately, you don't have to worry about any of this, as LoFi is preprogrammed to handle it. You just need to find fascinating things in your house to wire up!
Sender Schematic
06/20/2014 at 23:38 • 1 commentThe schematic for the sender is fairly simply, because the part count is low to reduce cost.
Noteworthy aspects include:
* The digital input is a general trigger to send data. That particular pin can also wake the ATtiny from a deep sleep (very low power mode). An optional pushbutton (SW1) is useful to manually send the data when debugging.
* Notice how the pins are reused for connecting to the transmitter, USB serial cable, and ISP6 Atmel programmer.
* The sender asserts high/low during transmission, but switches the TX pin to an input when idle. R3 gently pulls down the TX line to keep the transmitter board turned off. However, the USB serial cable connector (not shown) uses a 10 kilohm resistor to bring the signal back to serial idle standards (high). A simple trick to be compatible with both cases.
* The reverse battery protection diode (D1) has an ultra-low dropout. It is less than 0.1 V at LoFi's voltage and current draw: http://www.nxp.com/documents/data_sheet/PMEG1030EH_EJ.pdf
