Here's the diagram showing the way parts are assembled:
This is the led--note that I have shrink wrapped all exposed conductive surfaces.
This photo shows the Ping transducer, photocell and 30K (approximate) resistor.
Note that the Ping transducer has only three pins--many similar devices have four pins and that impacts the circuit connections and software.
