#### Introduction
Some of our beta testers have been reporting a colour problem in the uploaded templates. Time to fix it.
#### Steps
#### Follow on goals
# Resources
# Live Notes
###### 01/10/2016-18:33:23 GMT+1:
Started mapping
###### 01/10/2016-18:35:30 BST:
Need to find some examples.
###### 01/10/2016-18:37:58 BST:
Let's look at http://designs.theopenvoicefactory.org/e87ad0006c19a37d4cf6addf6d5f3333/
This is the results.
###### 01/10/2016-18:39:18 BST:
But this is the original.
###### 01/10/2016-18:40:06 BST:
Okay, let's look at the json file. It's here: http://designs.theopenvoicefactory.org/e87ad0006c19a37d4cf6addf6d5f3333/pageset.json
###### 01/10/2016-18:41:10 BST:
Okay, the top two (as in the ones that should be grey and are instead white, haven't got a colour entry - so it happened between the PowerPoint and the json, NOT the json and the browser.
###### 01/10/2016-18:43:02 BST:
I've confirmed that the grey that works is exactly the same RGB (191*3) as the one that didn't.
###### 01/10/2016-18:43:26 BST:
So now what?
###### 01/10/2016-18:45:29 BST:
git checkout -b colourbug
###### 01/10/2016-18:46:17 BST:
running
./create.sh testinputs/CK20V2.pptx 5
to check the same behaviour works offline.
###### 01/10/2016-18:48:19 BST:
Okay, we get the same behaviour offline, so I'm going to add some debuging code.
###### 01/10/2016-18:50:31 BST:
Hmmm... There's an amzing number of exceptions in the colour section. Let's see if we can do some more debugin.
###### 01/10/2016-18:52:27 BST:
It turns out we get this exception:
TypeError: a transparent (background) fill has no foreground color
Which we've been swallowing for a while. It's talked about here:
http://python-pptx.readthedocs.io/en/latest/user/autoshapes.html
My working hypothosis is that, because I'm working thought *all* of the objects, I'm getting all of the text ones as well.
###### 01/10/2016-19:09:38 BST:
I'm doing some more debuging, getting NOTvery far. Hypothisis was wrong.
###### 01/10/2016-19:18:46 BST:
Okay, the exception is only being raised for rectanges. Not folder colours, and NOT picture. Le'ts try something silly.
###### 01/10/2016-19:23:09 BST:
I'm trying replacing the ones that fail in powerPOint, with the ones that work.
###### 01/10/2016-19:24:22 BST:
No dice. Still the same problem, even if I literally copy and paste a working one.
###### 01/10/2016-19:24:48 BST:
Let's try Just changing the target colour.
###### 01/10/2016-19:29:41 BST:
Oh - it might be that I was changing one file and using the other. Hang on. Something is happening.
###### 01/10/2016-19:32:52 BST:
Okay. Changing the tile on the PowerPoint template solved the problem. Which is great. My choice now is
* Work out what caused the problem and fix that.
* Write some code to detect missing colours and change *all* of the offending ones.
###### 01/10/2016-19:33:50 BST:
I suspect I'll go with option B But possibly tomorrow.
